Spray arms do not rotate on Siemens dishwasherSiemens
The impellers (water sprayers) of the SIEMENS dishwasher do not rotate. There is not enough water pressure. The detergent does not dissolve.
 Re: Siemens dishwasher spray arms do not rotate
Post by Fulcrum »
Something wrong with the recirculation pump?
igor. kotov
Post by igor. kotov »
Hello. On my machine, the lower repeller began to touch the lid of the salt tank with one edge, sometimes it rests, which is why the dishes in the lower compartment are not washed. I took it off, straightened it (I put it under the press at night), but after a couple of times it still touches and sticks. Why and who encountered it? Maybe some advice
  • Dishwasher Candy/ Upper impeller does not rotate
    by Nadezhda Shk » » in Candy
    Last post by Nadezhda Shk
  • Remove the upper spray arm
    by adalgur » » in Other manufacturers
    Last post by Anal cough
  • Innovosh does not rotate well
    by Nicholas » » in Midea
    Last post by Harhar
  • The middle and top sprinklers do not rotate
    by enzof » » in Burning
  • The upper wing (impeller) does not rotate.
    by slavvio » » in Beko
    Last post by Anna
