Dexp g11d6pf seems to be heating, but it doesn’t seem to beOther manufacturers
yayalta@mail.ru
Post by yayalta@mail.ru »
Hello everyone!
Pmm it started to wash badly. I ran the diagnostics and everything seemed to be normal. But! Measuring the temperature using a thermocouple on a multimeter, it turned out that the heater heats up to a temperature of 70 degrees and then turns off. The temperature drops to 24 and that’s it. Then at the end of the cycle it heats up again to 70 and turns off again. At the same time, the water in the pmm is cold. Replaced heater and temperature sensor. There is no result. 🤔
Aerohod
 Re: Dexp g11d6pf seems to be heating, but it doesn’t seem to be
Post by Aerohod »
yayalta@mail.ru, did you find the reason???? I have the same problem, does not heat the water
yayalta@mail.ru
Good evening. I also encountered the same problem today. Has anyone solved it? I installed a new sensor, 10 kOhm. Some say you need to add resistance.
  • Dexp g11d6pf seems to be heating, but it doesn’t seem to be
    by yayalta@mail.ru » » in Other manufacturers
    Last post by yayalta@mail.ru
  • Doesn't heat water. Heating element repair
    by mario » » in Bosch
    Last post by Ivan 1909
  • Car dexp m9c7pd
    by Graphics » » in Other manufacturers
    Last post by Graphics
  • DEXP M6C7PD
    by 6aJIakJIaBa » » in Other manufacturers
    Last post by Luntik
  • DEXP M12C7PB
    by John mcClane » » in Other manufacturers
    Last post by John mcClane
