doesn't heat waterSiemens
Vitana
 doesn't heat water
Post by Vitana »
The machine stopped heating the water; the heater rings; the thermal sensors are checked; one is 100 ohms when heated; the other is open; when heated, it turns on at 35 and 60 degrees. What :sorry: could it be?
 Re: does not heat water
Try cleaning using these instructions viewtopic.php ?f=21&t=172
  • doesn't heat water
    by care » » in Bosch
  • Doesn't fully heat the water
    by @ntonov1968 » » in Hotpoint-Ariston
    Last post by @ntonov1968
  • Bosch doesn't heat water
    by Scorpio » » in Bosch
    Last post by Cuth
  • Doesn't heat water esl94201lo
    by Sergei1967 » » in Electrolux
    Last post by Sergei1967
  • First start. Doesn't heat the water and turns off after 20 minutes :(
    by Lisa » » in Bosch
    Last post by Chipmunks
