First start. Doesn't heat the water and turns off after 20 minutes :(Bosch
Lisa
Post by Lisa »
Good day to all. I bought a Bosch SMV25EX00E PMM. They turned on the network, brought out the sewer system and water through a filter system (they hadn’t put it in place yet). Filled all compartments (salt, tablet and rinse aid) we turn on the auto mode (65 degrees) and after 20 minutes it beeps and the faucet is on, the water is cold and stands at the bottom of the dishwasher:(
What to do? It’s just a print some :(
Chipmunks
 Re: First launch. Doesn't heat the water and turns off after 20 minutes :(
Post by Chipmunks »
Most likely due to the filtration system, the water pressure is too weak.
  • doesn't heat water
    by care » » in Bosch
    by Vitana » » in Siemens
  • Bosch doesn't heat water
    by Scorpio » » in Bosch
    Last post by Cuth
  • Doesn't fully heat the water
    by @ntonov1968 » » in Hotpoint-Ariston
    Last post by @ntonov1968
  • Doesn't heat water esl94201lo
    by Sergei1967 » » in Electrolux
    Last post by Sergei1967
