The machine stopped heating the water; the heater rings; the thermal sensors are checked; one is 100 ohms when heated; the other is open; when heated, it turns on at 35 and 60 degrees. What :sorry: could it be?
Hello everybody! I would like to describe my experience of repairing a Bosch dishwasher with my own hands, maybe it will be useful to someone. After 3 years of operation, the dishwasher produced strange variations of indicator lights and wet dishes at the end of the wash. Because Having never been in a dishwasher, it was decided to call a professional. The master arrived very quickly and with the...
What resistance should there be at the terminals? The same thing stopped heating, on the contacts with the red wires there are 19 ohms, there is no call to the ground, the sensor is the same 11 ohm on each arm and between 22.
Most likely the heating element of the circulation pump burned out. It can be repaired or the pump assembly can be replaced. There in one pump there is both the pump itself and the heating part.
Sent after 5 minutes 53 seconds:
If interested, here is my experience outlined in a detailed video
-agfU5196cI
Hello! I stopped heating the water. The heating element seems to ring (25.5), but the contacts come to some kind of ceramic insulators or something else and there is 0 resistance on the contacts. Is this how it should be?
Good day to all. I bought a Bosch SMV25EX00E PMM. They turned on the network, brought out the sewer system and water through a filter system (they hadn’t put it in place yet). Filled all compartments (salt, tablet and rinse aid) we turn on the auto mode (65 degrees) and after 20 minutes it beeps and the faucet is on, the water is cold and stands at the bottom of the dishwasher:(
What to do? It’s...
Most likely due to the filtration system, the water pressure is too weak.
