Hyundai DT505 - does not heat waterOther manufacturers
OtherDen
Post by OtherDen »
Good afternoon.
The machine is only half a year old, it worked just fine from the start.
A month ago it started not heating the water, and subsequently did not wash the dishes.
When you start it a second time, let’s say 90 min. (the same dishes, without a tablet) there is heating, but they are as they should be (straight steam with a rocker)
But again, for no apparent reason, it started working normally, washes perfectly, heats water, dishes creaks.
A week later, it returned to the “cold state”, during the washing process, I specially brake, touch the water - ice. The tablet seems to dissolve, but of course it doesn’t rinse properly.
I have an extended drain (2 parts in a connection), the machine is at the level of the drain.
Call a repairman under warranty or you can should I do something?
  • Filled PMM Hyundai 480
    by Tatyana3915 » » in Other manufacturers
    Last post by Construction plant
  • Hyundai 480 do I need to restart the program after E1
    by Yuri B. » » in Other manufacturers
    Last post by Yuri B.
  • doesn't heat water
    by care » » in Bosch
  • ESI 9620 lox does not heat water
    by Shmel » » in Electrolux
    Last post by Shmel
    by Yulia » » in Electrolux
