Dishwasher candy, can’t start ⇐ Candy
Автор темыdimasik69
Good day to all! Help please, I bought a CANDY tabletop dishwasher, connected everything, but it fills with water, then something quietly buzzes for 3-4 minutes, then the program resets and drains the water... maybe someone can tell me where the problem is and how to overcome it. I tried all the programs - no difference, everything is the same. Doesn’t spray water, doesn’t heat... Thanks to whoever responds!!!
Re: Candy dishwasher, can’t start
dimasik69, maybe something with the water sensor? Try to tilt it slightly in different directions when it fills with water.
Автор темыdimasik69
Got it!!! It turns out she doesn’t want to work without water pressure. Although I bought it for my dacha, and before buying it I surfed the Internet on this very issue. And it was said that it can work without connecting to the water supply system. It’s just that the water tank is higher and the difference in height causes it to fill and work. It’s complete bullshit. Does not work. Today I brought it home, connected it to the system and everything is OK! I’m closing the topic.
Автор темыdimasik69
the lily
I also have a problem - the machine runs for 7-10 minutes, drains and beeps. The water pressure seems to be normal, because the column is working, I turned it as advised about the valve, everything is not right. Under warranty, can I call service?
Pavel
In the Candy CDCF 6S-07 machines, there are no water level sensors; the water level is determined by pressure; if water gets into the tube (for example, the machine was turned over during delivery), you will have to open it to blow out the water that got there from the pressure sensor tube. After this everything works as it should. The manifestations of this defect are as follows: when you turn on the machine to any program, first the pump works, then the water supply valve should open, but it does not open, the machine waits for 3 to 5 minutes, then notifies about the accident and lights up 3/1 as an alarm...
Sting
Dishwasher Candy CDP 4709-07. I bought it, installed it, added all the detergents, press the on/off button - the display lights up, stays on for 1-2 seconds and goes off. If you do not release the on/off button, the display lights up, you can even select programs, but nothing can be launched, because... When you release the power button, everything still goes out. The instructions don’t say anything about this. I tried connecting to other sockets - the same song. Everything is fine with the water pressure at the inlet of the hose - the washing machine from a parallel pipe works normally. Tell me, what could be the reason?
Is there grounding in the wiring?
Looks like the emergency shutdown is triggered.Tibo: the display lights up, stays on for 1-2 seconds and goes off.
seems to be present. New building, wiring 3*2.5 mm. Tried it in 3 sockets. Again, the washer works smoothly
Sting
I’m thinking, maybe it’s a matter of "Aquastop"? Maybe it malfunctioned and turned off the water? Or if there is no water, should it still turn on at the display level and write an error?
Of course, it should turn on without water. In my opinion, it’s a matter of "brains." If there is a warranty, servicemen must come and pick it up for repair. And in exchange for the duration of the repair, give a replacement one.
Catherine
Exactly my situation. Please tell me how to get to this sensor? Or will I still have to return this car under warranty?
Pavel:Candy CDCF 6S-07 machines do not have water level sensors, the water level is determined by pressure if water enters the tube (for example, the car was turned over during delivery), you will have to open it to blow out any water that has got there from the pressure sensor tube. After this everything works as it should. The manifestations of this defect are as follows: when you turn on the machine to any program, first the pump works, then the water supply valve should open, but it does not open, the machine waits for 3 to 5 minutes, then notifies about the accident and lights up 3/1 as an alarm...
galina
Dishwasher Candy CDI P96-07 does not start.
On the panel, when you press the on/off button, all the indicators first light up, then only the rinse aid and salt indicators go out and light up, and the number 22 (sometimes 21) appears on the display. The machine does not start. True, they didn’t add salt, but was that really why the machine didn’t start? At the same time, the machine does not respond to the program selection button, only the on/off button works.
Please tell me
is the problem in the salt or could it be something else?
What do error codes 21 and 22 mean?
Please tell me
Anton
Tell me how you solved the problem of starting the PMM?
nI have a similar model and it gives the same error on startup.
Good afternoon.galina: The Candy CDI P96-07 dishwasher does not start.
Please tell me
the problem is similar. It turns out that the power button has a sinking (fixing) effect. It must be pressed in, then it works.Tibo: Dishwasher Candy CDP 4709-07. I bought it, installed it, added all the detergents, press the on/off button - the display lights up, stays on for 1-2 seconds and goes off. If you do not release the on/off button, the display lights up, you can even select programs, but nothing can be launched, because... When you release the power button, everything still goes out. The instructions don’t say anything about this. I tried connecting to other sockets - the same song. Everything is fine with the water pressure at the inlet of the hose - the washing machine from a parallel pipe works normally. Tell me, what could be the reason?
guest12
the display lights up, stays on for 1-2 seconds and goes off. The power button is not pressed all the way. It is fixed in a recessed state. I have 4609x-07, similar
Candy dishwasher won’t turn on when I close the door, the lights come on
I turned it on, for some reason the delay light came on for 3 hours, although I didn’t press that button, the car was working, then the indicator went off for 3 hours, came on for 6 hours, then after short signals for 9 hours, the car is quiet, I’m waiting to see what happens next
I turned off the car, washed it normally, now what should I do if the indicators light up again for 3, 6, 9 hours. ???
Hello, please tell me. I turn on the dishwasher, the operating modes start blinking one by one
9169645484@mail.ru
Hello, Kandi cdcf6, after replacing the drain pump (during testing, the pump drained the remaining water), when turned on, the on/off indicators light up; *; eco. No button switches programs and the machine itself does not turn off. What can be done? Thank you!
Tatiana
After replacing the Kandi cdcf6 drain pump (checked that the water is drained), when turned on, the on indicators immediately light up; *; and eco. The buttons do not respond to pressing. The program does not switch and the machine does not turn off at all. What can you do here? Thank you.
12 Russian
beeps, all the lamps light up and go out - as if the protection is triggered.....
what should I do?
what should I do?
Mick
And how was the problem solved? I have the same nonsense, and also a new machine.
Dishwasher Candy. After starting, the machine works, then a beep sounds and it stops, then it can start again, then stop again. This may happen several times, it may freeze for a long time, or it may not freeze even once. It’s as if some kind of protection is triggered somewhere. Has anyone encountered this? The same thing happens when you open the door (but it’s designed that way - it stops when you open it).
Sergey197
Hello) I started the machine once and at the end it stopped, I turned it off! Now it solves it and nothing works (what’s the problem?
Larisa
The Candy CDI 9P50/s dishwasher does not start.
Please tell me
Please tell me
Aleksandr1987
Candy CDI P96 programs did not start, only the powder and salt lamps were on. When the door was open, the program was set. I closed the door and the cycle began.
Hello! Pmm candy cdcf 6 when you turn on the power button, the wash delay buttons start blinking, not a single mode is turned on and the machine does not start.
How to connect please send with photos and recommendations of the KANDY 457 E dishwasher
Edya
Kandy CDCF 6S_07 draws water and is silent. Turn it off again, drains the water and silence. Tell people what to do.
galina: ↑04 Mar 2015, 05:09 On the panel, when you press the on/off button, first all the indicators light up, then only the rinse aid and salt indicators go out and light up, and the number 22 (sometimes 21) appears on the display. The machine does not start. True, they didn’t add salt, but was that really why the machine didn’t start? At the same time, the machine does not respond to the program selection button, only the on/off button works.
Easy Cleaning System
The start button on the PMM Candy Brava does not work. All the buttons on the display work but the start button does not respond. Please tell me what is the problem?
Bezzamkovy
Good day everyone, I bought a built-in dishwasher candy cdin 3d632 hd-07, I decided to test it without connecting to the water supply and sewerage, plugging it only into an outlet, the buttons do not respond, only the word "ENGLISH" appears on the indicator, please tell me whether there should be buttons active without complete dismantling?
Galloping
Tell me, did you manage to figure out what the problem was? The same thing, the CDCF6 machine drains water when you start any program, then adds a little new water and then nothing happens.
Air Shower
9169645484@mail.ru: ↑06 Feb 2016, 13:56 drain pump (during testing, the pump drained the remaining water) when connected to the network, the on/off indicators light up; *; eco. No button switches programs and the machine itself does not turn off. What can be done? Thank you!
- 4749 Views
Last post by Nadezhda Shk
- 31814 Views
Last post by Nushka
