The upper impeller has stopped rotating. Water flows into it actively. No leaks found. The pressure is good.
We pulled out the top basket. We checked by connecting the shower hose. In normal condition, water flows, the impeller does not rotate. Turned the basket upside down. Water flows in and the impeller rotates. What could be the reason?
Dishwasher Candy/ Upper impeller does not rotate ⇐ Candy
Автор темыNadezhda Shk
- 2 Replies
- 15448 Views
Last post by igor. kotov
- 5513 Views
Last post by deadog
