The upper wing (impeller) does not rotate. ⇐ Beko
slavvio
Good luck to everyone.
Forum members, please tell me.
The upper rocker arm has stopped rotating. The jets flow through it, and not weakly.
The pump seems to be working normally. But something is still preventing the rocker from rotating.
There is a suspicion that the fluoroplastic gasket at the point where the rotating
part is attached to the stationary part has worn out. Although, it feels like nothing is stopping the rotation.
Could the above be the cause of the malfunction?
Thanks in advance.
Thanks in advance.
Truffle
Re: The upper wing (impeller) does not rotate.
I have the same. The upper impeller rotates by hand noticeably more than the lower one, which was recently replaced due to a leak. Remains of the secondary plastic gasket spilled out during inspection. I think I need to go get a new sprinkler.
- Участник
Try checking the holes on the edges of the spray arm; if they are clogged, it may not spin
Good afternoon In the VEKO dishwasher, both impellers do not rotate, the lower one is new, the upper one seems to be working, all the holes are clean, both rotate easily by hand, there seem to be jets from all the holes, but there is no rotation. Where to look for the reason?
brutal
in my case, on the upper basket when closing, there are two holes in the body, one of them is closed by a plate valve, this is where there is no tightness
, I made a round plug made of plastic, inserted into the unnecessary hole and secured with electrical tape = test run - the upper rocker rotates
Guest, check the impeller of the pump to ensure that foreign objects do not get into it, and check the water distributor located after the pump
Good day. I have a Beko 5831 dishwasher. The problem is the following: the impellers have stopped spinning. Water splashes through them, but there is no rotation. I took apart everything I could. Visually everything is perfectly clean, everything is spinning and spinning. It heats the water and drains it. The impellers are clean and spray from all holes. It feels like there is not enough pressure. I think that the valve is a distributor (if I understand correctly, it is the one with a disk with holes of different diameters). How can I check it? Thank you in advance.
Romario 21
- Интересующийся
How can I check it? This is the big one that stands in front of the shade or the one at the bottom of the machine.
AleksandrN
The upper impeller also stopped spinning, the reason was found. din 24310
the water pipe to the upper basket is torn along the seam, it is made of PP plastic, it does not stick, but the blue electrical tape rules)
Graphics
I think the three-way valve (actuator) is broken. Water flows but there is not enough pressure. I had this reason
AlekSles
But only the lower rocker arm doesn’t rotate, or rather, it either works or doesn’t, the upper ones both rotate, and the small additional one at the bottom rotates, but the large lower one doesn’t! Who knows what’s wrong
AlekSles
But only the lower rocker arm doesn’t rotate, or rather, it either works or doesn’t, the upper ones both rotate, and the small additional one at the bottom rotates, but the large lower one doesn’t! Who knows what’s wrong?
Beko DIN 28320
Beko DIN 28320
Kreutzkopf
Malfunction: does not wash well, does not wash off detergent.
Brand: Gorenje.
Model: Gorenje + GDV664X.
The upper impeller does not rotate, there is little water pressure from the holes. Please tell me what could be the reason
Brand: Gorenje.
77Dmitry
Check the seal between the rocker arm pipe and the pipe on the back of the dishwasher, these rings wear out and the pressure disappears there, also parts of the rings get into the impeller
Anna
How can you tell if the blades are not rotating during the washing process? New Hansa and I foolishly put a large plate right under the blades((now I’m wondering how to understand during the next wash whether this blade works or not
- 4779 Views
Last post by Nadezhda Shk
- 5530 Views
Last post by deadog
- 4 Replies
- 30969 Views
Last post by Harhar
- 4985 Views
Last post by AVVK
- 40256 Views
