The middle and top sprinklers do not rotateBurning
enzof
Новичок
My dishwasher: Gorenje GV66161
Post by enzof »
Good day. The machine began to wash poorly; experimentally I discovered that the middle and upper sprinklers did not rotate. What could be the reason? Thank you in advance. Machine Gorenje 66161.
 Re: Middle and top sprinklers do not rotate
Something is clogged in the side holes of the sprinklers, where the water comes from. Most often they become clogged due to hard water, check them. https://youtu.be/mk6SoKcVp4g?t=3m36s
  • The machine just turns off in the middle of the program, what should I do?
    by Victor » » in Other manufacturers
    Last post by healing_otdubochka
  • Innovosh does not rotate well
    by Nicholas » » in Midea
    Last post by Harhar
  • The upper wing (impeller) does not rotate.
    by slavvio » » in Beko
    Last post by Anna
  • PMM LG LD2060WH lower rocker arm does not rotate
    by Wisdom » » in LG
  • Spray arms do not rotate on Siemens dishwasher
    by Guest » » in Siemens
    Last post by igor. kotov
