Dishwasher Candy Trio 9501 does not fill with waterCandy
Dishwashers Candy
Nicholas
My dishwasher: Candy Trio 9501
Post by Nicholas »
Good afternoon!
This is not the first time that the Candy Trio 9501 dishwasher has stopped filling with water.
The program starts, but there are no operating sounds. After about three minutes an error signal is issued.
The existing water is also not drained.
I called the experts twice with the same story. According to the craftsmen, they changed the heating element, removed it a second time and put on the drain hose.
I can’t say whether this was really the question.
After that, after a couple of months, the question is repeated.
nAt the same time, the machine has been problematic in recent years. If you don’t fill it with boiling water once a week, then during the washing process the PMM stops and starts beeping and giving an error.
What could this be? I would be grateful if anyone could share the error codes if they exist for this model.
 Re: Candy Trio 9501 dishwasher does not fill with water
Nikolay, check the air chamber of the pressure switch - most likely it is clogged with grease. (The large black plug installed at the bottom of the filter housing (oblong) is secured with a clamp) . Tilt the machine back 45 degrees (be careful not to break the water inlet and outlet at the back). Then, closer to the front surface, just to the right of the center below, you will see a black rubber plug (6-7 centimeters in diameter), open the clamp with pliers and remove it. Pull out the plug. Carefully clean and rinse everything inside. Do not press on the thin wall inside the filter, you may break it! Also look at the tube to the pressure switch, it may be clogged, clean it (the small transparent tube coming out of the air chamber. I hope this will help you. Good luck!
  • The Kandy trio doesn't fill the water.
    by rhodion » » in Candy
    Last post by Sergey
  • candy trio 9501x water intake valve does not turn on
    by borodinaries » » in Candy
    Last post by borodinaries
  • PMM Candy Trio 9503
    by Konarevv » » in Candy
    Last post by Konarevv
  • Candy trio 9501x does not complete cycle
    by Slawka » » in Candy
    Last post by Slawka
  • PMM Electrolux does not fill with water.
    by Maksim » » in Electrolux
