The Kandy trio doesn't fill the water.Candy
Dishwashers Candy
rhodion
Post by rhodion »
Good day. After selecting the program, close the Kandy trio. The pump starts immediately. And it doesn’t stop working for 4-5 minutes. After this it starts beeping. In short, it does not switch to the next Water Filling mode. All water leaves the system. Even if you forcefully top it up from (for example) a can. There is no aqua stop. please tell me what to do.
DeniS007
 Re: Kandi trio does not fill water.
Post by DeniS007 »
Good evening, 99.99% this is ten.
DeniS007
Post by DeniS007 »
Remove the terminals from the heating element and run the program. If the fill and wash starts. Replacing the heating element.
Top
Post by Top »
The problem is the same; I removed the terminals from the heater, the program started, it took in water and washed in eco mode (I chose this one), although it had not been run in any of the programs before, only the pump was working).
I checked the heater with testers, it seems to be ringing.
What resistance should a working heating element have?
Logically (I’m an electrician myself) I can’t understand how the heating element is included in the logic chain of the PM Machine’s operation??
Do all the heating elements have the same candidate or do we need to look for a specific model?
Candi-trio PMmashina 501, what heating element costs?
And another question: the backlight in the oven does not light, I checked the lamp is working properly. Where to look, dig.
Sergey
Post by Sergey »
There was a similar problem with candy duo 609 x. I called a technician from a certified service center. With him, the machine worked normally, he measured the resistance of the heating element and said that it was normal, that most likely the “brains” were dying, but they were not available. As a result, after a couple of days the machine refused to work at all, so I started Googling and studying YouTube on this topic. I came to this site and read about turning off the heating element. With the heating element turned off, it worked with a bang. As a result, I bought and replaced the heating element. Everything is working. The old heating element had a hole in the body.
  • Dishwasher Candy Trio 9501 does not fill with water
    by Nicholas » » in Candy
  • candy trio 9501x water intake valve does not turn on
    by borodinaries » » in Candy
    Last post by borodinaries
  • PMM Electrolux does not fill with water.
    by Maksim » » in Electrolux
  • Electrolux ESL94300LA does not fill with water
    by Jan007 » » in Electrolux
  • Flavia Ivela does not fill with water after winter
    by gesha » » in Flavia
    Last post by gesha
