Candy trio 9501x does not complete cycleCandy
Dishwashers Candy
Slawka
Post by Slawka »
When turned on, only the first stage is processed (filling can be heard as the valve operates, washing, draining may be completed, or not) and so on for all programs
When restarting with water, if it does not drain (draining can be heard as the valve operates, there is no water, filling can be heard how the valve operates, washing, draining may occur, may not).
Upon completion, all the lights flash.
The blades fell apart on CIRCULATION PUMP on the upper and lower parts (as if the thread had been torn off) whatever you glued is enough for 1-2 months
  • candy trio 9501x water intake valve does not turn on
    by borodinaries » » in Candy
    Last post by borodinaries
  • PMM Candy Trio 9503
    by Konarevv » » in Candy
    Last post by Konarevv
  • Bosch 33A13/14 does not heat water, the cycle does not complete
    by Serg_Ekb » » in Bosch
  • Bosch SMV25FX01R does not complete cycle, faucet blinks
    by Not a bit » » in Bosch
  • Dishwasher Candy Trio 9501 does not fill with water
    by Nicholas » » in Candy
