Bosch 33A13/14 does not heat water, the cycle does not completeBosch
Serg_Ekb
Post by Serg_Ekb »
Bosh 33A13/14 does not heat water, the cycle does not complete
The resistance of the heating element corresponds to the power (it has not applied direct voltage yet), the temperature sensor changes resistance when heated from 50 to 15 kOhm.
In the case with A water presence sensor is embedded with a heating element; water presses through a rubber membrane on the piston, and it presses on the microscope. There are doubts that it shorts, but I simply bypassed it.
They write that there must be a pressure switch somewhere - I can’t find any pressure switch.
I measured the voltage on the heating element during the washing process - about 120 volts. What could it be?
Serg_Ekb
 Re: Bosh 33A13/14 does not heat water, the cycle does not complete
Post by Serg_Ekb »
I’ll add - the first thing I did when it broke was to clean all the filters, + fill in various detergents and turn it on. Ten without plaque.
Serg-Ekb
Post by Serg-Ekb »
I didn’t think of measuring the voltage not on the heating element, but on the contacts, disconnecting them from the heating element. It’s still standing disassembled. Looks like the control unit is the cause.
The soldering of the heating element electromagnetic relay has fallen off on the control board. That is, I just melted away from long work. The relay itself is intact, just soldered. But during disassembly and reassembly, one of the connectors crumbled; it will have to be replaced or some kind of collective farm attached.
  • The dishwasher does not clean well, does not heat the water, and does not complete the cycle. Error "E". Repair methods
  • Bosch SMV25FX01R does not complete cycle, faucet blinks
    by Not a bit » » in Bosch
  • Candy trio 9501x does not complete cycle
    by Slawka » » in Candy
    Last post by Slawka
  • PHOTO GEAR RESTORATION BOSCH 33A13/14
    by alexbak2020 » » in Bosch
    Last post by Ayder
  • Stagnation of water after a Bosch wash cycle
    by salamon4ik84 » » in Bosch
    Last post by CorePureEmerald
