Bosch SMV25FX01R does not complete cycle, faucet blinksBosch
Not a bit
Post by Not a bit »
Good afternoon.
The machine has not completed the washing cycle, the faucet is blinking.
An opening revealed no leaks, filters, drain pump, drain hoses are clean.
After assembly, the machine started, draining when the door is opened and resetting the program works.
At the same time, the start of the new washing cycle also did not end (the water got hot), the faucet blinked, the drain went through, but water (warm) remained in the plastic container on the side wall of the machine (like a heat exchanger). Restarting also fails, while the pump that supplies water hums and clicks twice (probably some kind of relay). The drain pump is silent. It’s definitely not a leak. And I don’t think it’s the valve on the hose (otherwise the machine wouldn’t start again, but after some time or after disassembly it hangs down and starts again, taking in water).
I ask for help from specialists. What else needs to be checked?
 Re: Bosch SMV25FX01R does not complete the cycle, the faucet is blinking
Hello. Did you find the reason? I have a similar problem.
Guest: 02 May 2021, 12:46 In the morning after washing at night, I found it with the faucet on; it went out only after unplugging the plug from the socket for about 20 minutes. But the dishes were washed. A repeated idle start showed that the machine washes, draws and drains water, and after an hour and 20 minutes the tap lights up and the pump periodically works. According to the advice, I shook it and shook it, and dried it for 12 hours until the evening. Two washes - normal flight.
Bosch SPV25FX10R/46 NO LEAKS! the problems started in the middle of the cycle, the faucet stopped blinking and the pump did not drain, turned it off at night, then it worked 5 or 7 times and the faucet blinked again. Two weeks later it worked differently: no leaks! In the middle of the cycle, before rinsing, the water drains and the faucet blinks with error, I open the steam there, it comes out somewhere around 60 degrees, I try to start it, turn on any mode, close the door, two clicks occur, the pump and pump twitch and the faucet blinks again. Then, over the course of a month, every other day, it was started up a couple of times, doing full washes and again dancing with tambourines, again the error flashes, the water faucet is nowhere to be found, we start it, it clicks twice and the faucet again. Two days ago it somehow started up with a second-long hum and in the middle of the sink the pump again drained water and the ERROR TAP FLASHES. Now I think it’s completely screwed up, it won’t start at all. I TURN ON THE MODE, CLOSING THE DOOR. THERE TWO CLICKS OF THE RELAY AT ONCE AND SOMETHING IS JERKING AND INSTANTLY WRITES ERROR THE TAP IS OPENING, THERE IS NO LEAKAGE! I ASK FOR HELP, TWO MASTERS WERE SEEING ZERO.
I disassembled the machine myself, down to the screw, everything was clean and dry.
  • Bosch 33A13/14 does not heat water, the cycle does not complete
    by Serg_Ekb » » in Bosch
  • Candy trio 9501x does not complete cycle
    by Slawka » » in Candy
    Last post by Slawka
  • The dishwasher does not clean well, does not heat the water, and does not complete the cycle. Error "E". Repair methods
  • Bosch SGV57T23EU - When pressing ON, only the floor lamp blinks
    by Palmer » » in Bosch
    Last post by Palmer
  • Bosch SRV55T03EU/30 - does not complete washing after an hour of operation - cyclic glitch
    by Alex2110 » » in Bosch
    Last post by Alex2110
