ESL94201L0 does not heat waterElectrolux
Yulia
Post by Yulia »
Good afternoon After washing the dishes, a part was found at the bottom of the PMM (photo attached), we examined all the dishes, such a part could not have fallen off from anywhere! Accordingly, the part is from PMM! What could it be?? Or maybe immediately, or maybe after a couple of days (they didn’t pay attention right away), the machine stopped heating the water and drying! The filters have been washed! But when you open the machine during washing, the water does not completely go away, but stays at the bottom! Please tell me what kind of part this could be and what about the PMM? :(
 Re: ESL94201L0 does not heat water
The PMM always has some water left at the bottom, which is technologically conceived. Because Dishwashers most often use the condensation type of drying (using a temperature difference), then poor water heating will immediately affect the drying too, therefore it is necessary to solve the problem, first of all, of poor heating. Check the filters and drain carefully. If there is too much water at the bottom of the PMM the drain may be clogged. Read more about the reasons for poor heating here: http://posudomojki.ru /viewtopic.php?f=21&t=172
  • doesn't heat water
    by care » » in Bosch
  • ESI 9620 lox does not heat water
    by Shmel » » in Electrolux
    Last post by Shmel
  • ESL45010 does not heat water
    by JustAMan » » in Electrolux
    Last post by JustAMan
  • Electrolux does not heat water
    by chubarev1994 » » in Electrolux
    Last post by dubalex
    by Vitana » » in Siemens
