Electrolux does not heat waterElectrolux
chubarev1994
Post by chubarev1994 »
Good day, the electrolux dishwasher does not heat the water, the power supply to the heating element is 51V, while replacing the heating element itself, the circulation pump, the temperature sensor, the flow distributor, and even the control module, but the power supply still does not heat
You are white
 Re: Electrolux does not heat water
Post by You are white »
Have you tried plugging in the dishwasher?
Knockout
Post by Knockout »
Very funny
You are white
:thanks:
Retraction
Post by Retraction »
chubarev1994, good evening. How did you solve the problem? I have a similar one. PMM IKEA VALGJORD, 36-37 volts come to the heating element, and constantly, as soon as you turn on the PMM, these 36 volts immediately sit on the heating element. Of course, all cycles are without heating. Error: iE0 - couldn’t find the explanation anywhere...
Twinkle
Наблюдатель
Наблюдатель
Post by Twinkle »
Error in the control board. Re-flashing, repair or replacement of the board.
Retraction
Thank you!
dubalex
Post by dubalex »
Good afternoon!
I have the same problem (36V on the heater).
Can you tell me if flashing/repairing the control board helped? Which board was repaired, the one that directly supplies voltage to the heater (in my case, it is installed on the rear wall at the very bottom)?
  • Electrolux esf 2410 does not heat water
    by amulets » » in Electrolux
    Last post by amulets
  • Electrolux esf9552low does not heat water
    by psyhit » » in Electrolux
    Last post by Graphics
    by Yulia » » in Electrolux
  • Smv50m50ru /74 does not heat water
    by Chinese » » in Bosch
    Last post by Chinese
  • doesn't heat water
    by Vitana » » in Siemens
