Smv50m50ru /74 does not heat waterBosch
Chinese
Post by Chinese »
Good afternoon. The situation is this: the Bosch smv50m50ru car, after replacing the motor (actuator) for switching the water flow, stopped heating. Everything seems to have been assembled correctly. It works, the cycles go through, but the time doesn’t match now, instead of 30 minutes of quick washing, it washes for over an hour. And only cold water. Ten checked, 20 ohms. What could be the problem?
  • doesn't heat water
    by care » » in Bosch
  • ESI 9620 lox does not heat water
    by Shmel » » in Electrolux
    Last post by Shmel
  • ESL45010 does not heat water
    by JustAMan » » in Electrolux
    Last post by JustAMan
  • Electrolux does not heat water
    by chubarev1994 » » in Electrolux
    Last post by dubalex
    by Yulia » » in Electrolux
