Pmmm started to look like a wash. I ran the diagnostics and everything seemed to be normal. But! Measuring the temperature using a thermocouple on a multimeter, it turned out that the heater heats up to a temperature of 70 degrees and then turns off. The temperature drops to 24 and that’s it. Then at the end of the cycle it heats up again to 70 and turns off again. At the same time, the water in the pmm is cold. Replaced heater and temperature sensor. There is no result.
Dexp g11d6pf seems to be heating, but it doesn’t seem to be ⇐ Other manufacturers
yayalta@mail.ru
Hello everyone!
by yayalta@mail.ru » » in Other manufacturers - 2 Replies
- 5248 Views
Last post by yayalta@mail.ru
