The dishwasher uses more cubic meters of water than indicated in the specificationsBosch
Julia
Post by Julia »
Has anyone noticed that the dishwasher uses more water per cycle than indicated in the specifications?! We bought a Bosch spv66mx20r, used it 5 times, then out of curiosity I decided to check how much water it spends. I looked at the meter, turned on the dishwasher for an hour, didn’t use any more water during that time and it came out to 35 liters, compared to the stated 10! I checked this 2 times. The meter is working properly, it was a mistake, you wouldn’t even think about it...
Is this normal in general or should it be taken for diagnostics?!
Artem
 Re: Dishwasher uses more cubic meters of water than indicated in the specifications
Post by Artem »
When you turn on the VarioSpeed ​​mode, dishwashing time is reduced without sacrificing quality, water and energy consumption increases by 2.5 times! Also, during intensive washing programs and when additional modes are turned on for the main wash, the consumption of water or electricity increases! Try taking measurements on the ECO washing mode
  • Water does not flow into the dishwasher. No water. Reasons for the error.
  • Water in the dishwasher
    by Ekaterina.evstafieva » » in Bosch
    Last post by reached
  • Water in a new dishwasher
    by Valera and co » » in General questions about dishwashers
    Last post by pigeon
    by AndreyKursk » » in Indesit
    Last post by AndreyKursk
