1) The water supply valve in the main water supply is closed;
2) The water supply tap installed additionally in front of the inlet hose is faulty;
3) Dirt and slag components get into the receiving screen of the aquastop valve of the inlet hose or the drain is clogged (in this case, this instruction will help ), most often this happens after planned water supply shutdowns for seasonal maintenance or scheduled and unscheduled shutdowns during repair of the water supply network.;
4) The DRAIN hose is not raised 40 cm (lying on the floor), which leads to spontaneous drainage of water from the machine;
5) the water supply valve (aquastop) is faulty - it does not open when the machine is turned on, and in this case the inlet hose is replaced along with the aquastop.
Water does not flow into the dishwasher. No water. Reasons for the error. ⇐ Flavia
Автор темыMr.Cheese
- Участник
Novel
Re: Water does not flow into the dishwasher. No water. Reasons for the error.
Thanks for the detailed answer
Which inlet hose with hitch-stop for the flavia bi 45 niagara dishwasher should I buy?
there are a lot of them for sale on the Internet. Which one is suitable?
With respect
Sukhinin Roman Vladimirovich
+7 921 6056037
6056037@mail.ru
With respect
+7 921 6056037
6056037@mail.ru
Roman, write to info@flavia-rus.ru model name, serial number (available on the right side of the body) with a request to purchase a hose with aquastop, we will select in stock.
- 11082 Views
Last post by AndreyKursk
- 11585 Views
Last post by Kirill
- 37147 Views
Last post by Ingwarr
