Water does not flow into the PMM ⇐ Electrolux
Vitaly
Hello! We have a PMM Electrolux, the problem is that water does not flow into the machine. When you turn on the machine, the drain pump runs for a few seconds and then the machine stops. There are no leaks, what could be the reason please tell me.
Re: Water does not flow into the PMM
Vitaly, did everything work before or is this a new machine? Is there any indication of an error?
There may be approximately the following reasons:
1) the water tap is not open
2) the water supply hose is pinched
3) it is broken water intake solenoid valve (or control module)
the machine worked until they started turning off the water (3 days in a row, but the machine did not turn on during this period). when turned on, the pump works - pumping out water, the first time I unscrewed the hose from the water supply and blew it out, put it in place, the machine worked, the second time it doesn’t help(
Is there no water in the pan? Because if there is water, the float will not allow new water to be supplied.
Or the float is stuck... Try tilting the dishwasher sideways by 45 degrees.
There is no water in the pan. There is no water in the hose either (the drain turns on for 5-7 seconds and turns off
Then it turns out that the problem is in the valve. Either there is a blockage, or it has gone bad.
and where is it located? when I suck air from the hose and the water tap is on, the water does not flow(
Novel
I have some kind of gizmo on the hose where it is attached to the water supply) some kind of sensor
where the hose is attached to the machine and the wire comes off
a hose with aquastop, can it become unusable? Is there any way to treat this other than replacing the hose?
Maybe your water pressure is low? If it is below 2 bar, then the aquastop will not work.
the pressure is normal (tried to turn off the aquastop - the machine pumps out water for 5-7 seconds - it stops after 5-7 seconds, the pumping pump turns on again, when the aquastop is connected, the pump stops
The problem was not solved (a technician came and touched the wiring from the aquastop, everything worked)) but not for long, the next day there was peace and quiet and only the drain pump worked
Good afternoon. Water is dripping in my PMM due to the trim from the kitchen furniture. It doesn’t drip very much. Help!!! Your husband will do everything if you explain.
567
Guest, if there is dripping from the front, then the easiest thing is to check the sealing rubber on the opening door of the machine. Sometimes it comes off, or something sticks there, like a bone, and therefore water can leak out.
VLAD
Water comes in
: Hello, Everything is turned off, but the water comes through the side hole??? It turns on at 2h53min, and after two minutes it becomes 0h01min. Anyone in the know, please tell me
thank you tilted the water drained it worked))))
now I would like to understand where the leak is and why
the car was parked in an unheated dacha for 3 years?!
Most likely, the water in one of the hoses froze in winter and the hose ruptured. It is necessary to drain the water from the dishwasher before winter if it is left to winter in the cold.
By the way, be sure to drain the water from washing machines too! This is the only way hoses break!
pasture
everything works in the PMM, no water comes in, no leaks anywhere, the pan is clean and dry. What else could be the reason?
Stas
- My dishwasher: Elektrolux
Hello, can you tell me what could be wrong, the dishwasher turned off, I drained the water from the pan, it started working, but the water was dripping in a little
Boris
A new machine, turned on by a specialist, then did not work for a long time. Now everything is working, but no water is flowing. If you pour it, it works, but the water itself does not flow. What should I do?
When you turn on the machine, water does not fill in, and then when you open the door, the indicator shows 36
Catherine
I have low water pressure in my apartment. Tell me, does the PMM machine first draw in water, heat it up, and then under pressure (now PMM) spray it with rocker arms?
- Участник
For PMM you need a certain water pressure. PMM flavia minimum limit 0.04 MPa (this is slightly below the average level), information about the required pressure can be found in the instructions for the dishwasher, if your pressure is lower, then you can buy a pump that increases the pressure https://market.yandex.ru/product/470782 ... track=char or contact the installers for help.
Possible reasons - Water does not flow into the dishwasher. No water. Reasons for the error.
Alexei
We had the same problem. When using the machine, negative air pressure can form in the hose going to the water supply sensor. To fix this problem, you need to unscrew the panel located under the door of the machine, access to the hoses will open, disconnect the two hoses and attach them back .Put the panel in place and that’s it.
What should you do if water constantly flows into the pan? The dishwasher constantly works but no water comes out.
Hello, this is a question. The machine is 5 years old. When I turn it on, at first it seems to be noisy, and after a while a rhythmic beeping noise is added. It continues to make noise until you unplug it. If you open the door, water splashes everywhere... What kind of breakdown could there be with such symptoms?
- Участник
Most likely the aquastop does not work, here are the possible causes of this error: http://posudomojki.ru/viewtopic.php?f=21&t=175
Good night! And if the sensor in the pan worked, I drained the water, but how can I reset the error? Otherwise, the two top lights blink as before (overflow)
Can anyone tell me the number of the rubber ring of the seal (gasket) for the impeller volute of the circulation pump of the Electrolux ESF 43011 dishwasher?
Elena B
Good afternoon The Siemens PMM is more than a year old; when selecting a program, after a few seconds it gives a signal and no water flows. We checked everything (hose, filter), replaced the aquastop, but the PMM does not start. We connected it to the water supply on the street - it works there. Why doesn’t it work in the house? The water pressure is good.
- 11614 Views
Last post by Kirill
- 11110 Views
Last post by AndreyKursk
- 37169 Views
Last post by Ingwarr
