Water in a new dishwasherGeneral questions about dishwashers
Valera and co
Post by Valera and co »
Before New Year’s Eve we bought a completely new dishwasher, and when we started unpacking it we saw water inside. :( Not that much, but there were drops all over the bottom. Does this mean they sold us a used earphone that previous buyers refused?
We want to go after the holidays swear.
 Re: Water in new dishwasher
Valera and co, do you know if all such equipment (washing machines, dishwashers) are checked at factories? Do a test run with real water. The fact that the water has not had time to dry indicates that your machine was made not so long ago. Also a good sign. So enjoy your purchase!
Irina
Post by Irina »
We bought a new fully built-in Bosch dishwasher, tried washing dishes 2 times - everything was fine. After installation in a new kitchen, the machine was not used, and a week later they discovered that water had accumulated inside and began to leak onto the floor. Those. Water slowly dripped from the tap into the interior and over the course of a week about 5 liters accumulated and naturally began to flow out onto the floor. What kind of malfunction could this be?
Liberty
Post by Liberty »
If water is dripping from under the dishwasher, it could be a damaged pump seal or a leak in the fill or drain valve hose.
In your case, most likely the problem is in the fill valve hose.
Halyna
 Re: New dishwasher smells awfully musty
Post by Halyna »
When purchasing a Bosch dishwasher, I discovered that the inside was damp and there was a terrible smell of mold coming from it. What should I do, should I wash it or return it? After all, black mold is very dangerous to health and is very difficult to wash off.
Lentetta
Новичок
Post by Lentetta »
Buy a special product and ventilate the dishwasher
pigeon
Новичок
Post by pigeon »
Well, how did you solve the problem?
  • Water does not flow into the dishwasher. No water. Reasons for the error.
  • Water in the dishwasher
    by Ekaterina.evstafieva » » in Bosch
    Last post by reached
  • Connecting the dishwasher to hot water
    Last post by Sergey
    by AndreyKursk » » in Indesit
    Last post by AndreyKursk
