Bosch Srv 55to -- no water drain at the beginning of the cycleBosch
Alex2110
My dishwasher: bosch srv55to3eu
Post by Alex2110 »
The dishwasher does not drain water at the beginning of the working cycle - there is no characteristic noise. The tray is half full of water. The trouble appeared in a previous unfinished cycle. I reset the program. Now, only when the power button is turned on, the pumping pump bubbles; its cover is removed, but nothing interferes with the rotation of the impeller. What is the reason? What should I change?
Sent after 1 minute 39 seconds:
Alex2110
 Re: Bosch Srv 55to - no water draining at the beginning of the cycle
Post by Alex2110 »
In general, I didn’t drain it, I decided to check the cleaning filter, the movement of the pump impeller - everything seemed to be normal. Then I returned the pump cover to its place - it drained... BUT! I tried to set it to the "soak-rinse" mode - it seemed like the blades did not rotate and there was no such characteristic beating of water jets against the walls - maybe the problem is in the circulation pump and the latter does not create the proper pressure??? Or is the control relay in the control unit burned out? if it is there of course.
  • Stagnation of water after a Bosch wash cycle
    by salamon4ik84 » » in Bosch
    Last post by CorePureEmerald
  • Bosch 33A13/14 does not heat water, the cycle does not complete
    by Serg_Ekb » » in Bosch
  • Bosch resets the time, makes noise and does not drain the water HELP!!
    by Oleg » » in Bosch
    Last post by Oleg
  • Bosch SMV25FX01R does not complete cycle, faucet blinks
    by Not a bit » » in Bosch
  • Stopping GV62012 at the beginning of operation
    by Urs » » in Burning
    Last post by Urs
