Bosch resets the time, makes noise and does not drain the water HELP!!Bosch
Oleg
Post by Oleg »
When turned on at low speeds it makes noise, there is an assumption that it is a nose. When the program time reaches 1 minute, the machine immediately adds time to 3 minutes, after (about a minute) it shows the time 000 and does not understand the screen; when you open the machine, there is water below. What’s happened?
  • The impeller makes noise during the wash cycle
    by Tatyana_K » » in Bosch
    Last post by Matrix
  • Bosch Srv 55to -- no water drain at the beginning of the cycle
    by Alex2110 » » in Bosch
    Last post by Alex2110
  • Indesit DSG 5737 - noise and water does not flow to the lower rocker arm.
    by Ingwarr » » in Indesit
    Last post by Ingwarr
  • Help, soapy water all the time
    by Screw17 » » in General questions about dishwashers
    Last post by He remembers
  • p\m Bosch smv6 3m00eu/02 does not start the first time.
    by Danil » » in Bosch
