p\m Bosch smv6 3m00eu/02 does not start the first time.Bosch
Danil
Post by Danil »
Good afternoon.
Please tell me, this is a problem with the Bosch smv6 3m00eu/02 (installation), after selecting the program and pressing the start button, I close the lid and the motor or pump starts working, I don’t know exactly, and after about a minute It beeps as if the program is over, the water supply never starts.
If after pressing the start button and waiting for about a second. 30 open and close the lid, the pump works and it starts pumping water and then everything works fine.
Tell me, is there something wrong with the pump since it seems like you have to push it to operate again by opening the lid, or is it something else?
How can I cure it?
Thanks in advance!
 Re: Bosch smv6 3m00eu/02 does not start the first time.
Try to check the water supply for blockages, rinse the mesh on the supply hose; maybe the first time you do not have time to draw the required amount of water due to difficult supply.
  • Doesn't start the first time
    by aleksandra » » in Bosch
    Last post by Matrix
  • BOSCH SRV55T03EU/38 - wash program time is too low
    by Sergey (Khimki) » » in Bosch
  • Bosch resets the time, makes noise and does not drain the water HELP!!
    by Oleg » » in Bosch
    Last post by Oleg
  • Pmm Bosch won't start
    by Mikhail 80 » » in Bosch
    Last post by Mikhail 80
  • Bosch SVM40E10 after the start goes to the end of the wash.
    by Sciper » » in Bosch
