The impeller makes noise during the wash cycleBosch
Tatyana_K
My dishwasher: Bosch spv6emx11e
Post by Tatyana_K »
Hello. Help figure out. We bought a new Bosch spv6emx11e dishwasher. When the cycle starts, when the upper impeller begins to spin, a sound is heard, as if streams of water are hitting the walls or plastic. There are dishes in the machine. I ran it empty, the sound did not change. This is fine? Before this there was another machine and there were no such sounds. If you pull out the sprinkler closest to the door, the sound gets in. I swapped the far and near rocker arms, the sound did not disappear. Is this a Bosch feature or is my rocker arm faulty?
Matrix
 Re: Impeller makes noise during wash cycle
Post by Matrix »
What does far and near mean? There is an upper and a lower one, this is normal, streams of water scatter throughout the washing chamber, but you have problems with the sound insulation of the PMM, the PMM comes with soundproofing material, did you not install it?
Tatyana_K
Post by Tatyana_K »
Double top sprinkler. One rocker is closer to the door, the other further away. If you remove the one that is closer to the door, then this sound does not exist. This is why I ask, because I can’t understand whether this is the norm or not. It is precisely one sprinkler that is noisier than the engine and louder than all sounds from the machine in general. I’ll take a video later and attach it with sound.
Matrix
Post by Matrix »
If you remove the impeller and start the washer, the water will not splash in streams in any direction at all, there will be just a fountain, of course there will be no noise, maybe it’s really defective, or maybe sound insulation, I also have streams hitting in 5 directions, both against the walls and the door .
Tatyana_K
Post by Tatyana_K »
The sound appears for 5 seconds and continues up to 48 seconds, then the lower sprinkler begins to rotate, and this creaking stops.
https://drive.google.com/file/d/1qs2M1q ... sp=sharing. Listen, for those who don’t mind.
The problem is that the machine is not licensed for sale in Russia and there is probably no guarantee for it, which is why I did not contact an authorized service.
Matrix
Post by Matrix »
This shouldn’t happen, inspect everything carefully, maybe there’s a bone or something that’s touching something.
  • Bosch resets the time, makes noise and does not drain the water HELP!!
    by Oleg » » in Bosch
    Last post by Oleg
  • SMS40D02RU/34 Noise during main wash
    by nikita » » in Bosch
    Last post by 777
  • Stagnation of water after a Bosch wash cycle
    by salamon4ik84 » » in Bosch
    Last post by CorePureEmerald
  • Ariston LL 40 Turns on but does not start the wash cycle
    by zakkrnd » » in Hotpoint-Ariston
    Last post by zakkrnd
  • Hotpoint Ariston LSF 7237 Wash and cycle end error.
    by Alexei » » in Hotpoint-Ariston
    Last post by Kreutzkopf
