PMM turns on when the door is openBosch
atk-vis
Post by atk-vis »
I set the washing program, the front cover is open, the machine immediately turns on the drain pump, it works constantly.
When the cover is closed to the working position, nothing changes. Water for washing does not flow, the dishwashing process does not occur.
Take a leak
 Re: PMM turns on when the door is open
Post by Take a leak »
Possibly the float is stuck
  • The detergent compartment does not open
    by Jaqjaq » » in Hotpoint-Ariston
    Last post by Dmitry848
  • How to open the snail in the Willing YXW65-2A pump
    by Pavel » » in Hotpoint-Ariston
    Last post by bow
  • The tablet compartment does not open during washing. MODEL lft 116a/ha
    by Diana » » in Hotpoint-Ariston
  • The salt indicator lights up and water pours out when you open the tank.
    by Leon » » in Other manufacturers
    Last post by Leon
