The detergent compartment does not openHotpoint-Ariston
Jaqjaq
Post by Jaqjaq »
Hotpoint ariston, the soap/detergent compartment stopped opening automatically during washing, as a result, after washing the compartment is closed, the soap is wet and intact, the dishes are washed without detergent. Can I fix this myself?
 Re: Detergent compartment does not open
Same issue: dispenser won’t open
dkjpump
My dishwasher: ariston
Post by dkjpump »
Most likely the connector on the dispenser has come off, you need to disassemble the door and take a look.
And I have the same story with Hotpoint Ariston. What could be the reason, who solved the problem?
Also, the dispenser stopped opening, disassembled the door, measured the voltage on the dispenser drive - 220 is supplied 4-5 minutes after the start of the wash, but the drive itself does not work - it turns out that the problem is 100% in it, the electrics themselves are all intact. I will treat him.
Dmitry848
Post by Dmitry848 »
The winding needs to be replaced, suitable from an aquastop.
  • The tablet compartment does not open during washing. MODEL lft 116a/ha
    by Diana » » in Hotpoint-Ariston
  • Where should I put the salt? No compartment. Electrolux BW 545
    by Anatolian » » in Electrolux
    Last post by Ray
  • Liquid detergent
    by Ksusashsh » » in Bosch
    Last post by Vika-Nika
  • Liquid detergent
    by class 2.2 » » in Bosch
    Last post by Boil
  • Smell of detergent during PMM operation
    by Ivan » » in Electrolux
    Last post by alexander.team
