The salt indicator lights up and water pours out when you open the tank.Other manufacturers
Leon
Post by Leon »
Greetings to everyone!
On the AKPO ZMA55 dishwasher, the salt indicator lights up after several washes. When you open the lid of the salt container, water flows out. The last time I didn’t do anything, I just opened the container, the water flowed out - I closed it. After that, the indicator went out.
A couple of simple ideas - too much salt? Or do the washers need to reduce the water hardness in the settings?
  • Salt tank
    by Pre 07 » » in Candy
    Last post by Funtic
  • Is it possible to use PMM without a salt tank?
    by DoubleFace » » in General questions about dishwashers
  • DIS-4530 dry salt tank
    by certificates » » in Beko
    Last post by Yuri
  • Hansa ZWM 4577WH problems with the salt tank.
    by Alex86 » » in Hansa
  • The salt indicator does not go out.
    by Sergey.bobrovsky » » in Midea
    Last post by Guest)
