Is it possible to use PMM without a salt tank?General questions about dishwashers
DoubleFace
Post by DoubleFace »
The tank burst, replacement is expensive. But our water is already soft, there is no point in using salt. So, I think, maybe I shouldn’t change the salt tank, but just plug the inlet and outlet hoses? Who thinks what?
 Re: Is it possible to use PMM without a salt tank?
Salt is needed only to soften the water; if you plug the hoses, the dishwasher should most likely give an error message that there is no salt and continue to work, but this also depends on the manufacturer
DoubleFace
I think so too. But I’ll try anyway. The only concern is that the water will remain in the hoses and go out. I’ll post how it turned out
Is there water in the outlet hose? So there is always water in the PMM, but it changes periodically, and there is no option to pour out the water in this outlet hose? Subscribe, it would be interesting)
Same problem. How did you do it?
  • Salt tank
    by Pre 07 » » in Candy
    Last post by Funtic
  • DIS-4530 dry salt tank
    by certificates » » in Beko
    Last post by Yuri
  • Hansa ZWM 4577WH problems with the salt tank.
    by Alex86 » » in Hansa
  • The salt indicator lights up and water pours out when you open the tank.
    by Leon » » in Other manufacturers
    Last post by Leon
  • Bypass (bypass) of the salt tank
    by Georgiy » » in General questions about dishwashers
