Hello.
I purchased this miracle washer not long ago, the first time I turned it on, the salt light came on.
I filled in almost 1.5 kg and immediately filled it with water as per the instructions, the salt light went out. But during the first wash, the light came on again. After I took out the dishes and unscrewed the lid of the tank, I saw that the tank was almost empty.
The remains of water and salt were at the bottom. I disassembled the machine, checked the valve on the tank, it works.
I started the drinker and began to measure the voltage on the valve. During the entire washing cycle, voltage was not applied to the valve even once.
After that, I found 2 disconnected contacts under the bottom, one goes to the valve on the salt tank, the aquastop valve, and so on almost throughout the entire machine.
And the second goes to the machine control board. The water hardness level regulator in the salt tank is set to the middle position.
Tell me why there is no voltage supplied to the valve on the salt tank and what is missing in the machine, where are the contacts from?
I couldn’t find it on the Internet not an explosion diagram for a typewriter or at least a photo of this area.
Thanks to everyone in advance.
Hansa ZWM 4577WH problems with the salt tank. ⇐ Hansa
Автор темыAlex86
- My dishwasher: Hansa ZWM 4577WH
Re: Hansa ZWM 4577WH problems with the salt tank.
The Hansa machine washed perfectly. We didn’t add salt; the water in Primorye is good. After loading the salt, a white coating began to remain. I use tablets. I regretted loading the salt.
- Участник
- My dishwasher: Ariston LSV46ABK , Ariston LSV68DUO IX
- Участник
Is it possible to use PMM without a salt tank?
by DoubleFace » » in General questions about dishwashers - 4 Replies
- 32131 Views
- 36417 Views
Last post by Yuri
