We have Model
Indesit ICD 661 S
After washing I find these marks. Where to go, what to do?
Photo link
http: //s49.radikal.ru/i125/1501/42/1cf8c4c87394.jpg
Problems with the salt container lid ⇐ Indesit
Igor_
How old is the machine?
If this is not the result of corrosion, but simply a crack in the cover, then look for the same cover and replace it.
And if this is a result of corrosion, then it is unlikely that anything can be done. See how the dishes are washed, if everything is fine, then continue to use the machine. But at the same time, there is no point in adding salt. Saving )))
Lina
Yes, she’s only a month old. The lid was examined, everything seems to be intactIgor_:How old is the typewriter?
And if this is a result of corrosion, then it is unlikely that anything can be done. See how the dishes are washed, if everything is fine, then continue to use the machine. But at the same time, there is no point in adding salt. Savings)))
Igorek
If it’s a month, then there should be a guarantee. Because If the product is large, the warranty providers themselves must come and take it for repair (or fix it on the spot). Have you called the service center?
- 5 Replies
- 35543 Views
- 3 Replies
- 8810 Views
Last post by Sibiryak22
- 10512 Views
Last post by He will swing
