Error that is not in the instructions for P/M Samsung dw50h4030bbSamsung
Irinka
Post by Irinka »
P/M Samsung dw50h4030bb - the intensive wash indicator (pan) is blinking, this error is not indicated in the instructions, what could this mean? It pops up at the beginning of draining the water, after draining the water the washing cycle does not continue, what should I do???
Anna
 Re: Error that is not in the instructions for P/M Samsung dw50h4030bb
Post by Anna »
Were you able to solve the problem? The same garbage came out, I turn on the car, turn it on, everything is the same. There’s a problem, what should I do?
Anna
Post by Anna »
In general, the problem was that the water got into the wrong place. The problem was solved by tilting the car slightly forward, from where a little water flowed out. Now the machine is working fine.
Something similar happened - I turned off the car for 12 hours and ventilated it. Everything is over.
  • Dishwasher Samsung DW50H4030BB
    by Vadik » » in Samsung
    Last post by Yoh
  • PMM SAMSUNG, error "LC"
    by P » » in Samsung
    Last post by Booka
  • PMM Samsung DW50K4010BB error "tC"
    by Booka » » in Samsung
    Last post by Forage Harvester
  • Samsung dishwasher error E3
    by Andrey Shagrov » » in Samsung
    Last post by Andrey Shagrov
  • Samsung DW50H4050BB shows error 4E
    by Caves » » in Samsung
    Last post by andrewa4
