PMM SAMSUNG, error "LC" ⇐ Samsung
Автор темыP
Good day. I have owned a Samsung DW50K4010BB PMM for several years now, I didn’t have any particular complaints about the work, except for periodic jumps of the pressure switch, until recently... An error "LC" appeared, which signals a leak and the machine stops washing... I think, oh well , you never know... I took it out, checked everything.... Dry! The microphone rang, in all its modes, everything seems to be ok... Well, okay, I think, in order to rule it out for sure, I remove the chips from it, twist 2 wires, yellow and pink, together in order to imitate the normal position of the aqua stop a... I start the PMM.. Aaand.... Error again! Where to flattery, where to dig, are there El schemes for it??
Anatoly
Re: PMM SAMSUNG, error "LC"
My car had a similar problem. I didn’t take anything apart, I just tilted it forward, held it for a couple of minutes, shook it slightly and everything worked as before. The idea is not mine somewhere
I read it, I don’t remember where.
Lex1000
The same problem happened today. I was loading dishes, the machine was mixing and there was an LC error. I tilted it, it helped. Thank you dear man
Abyssinian Well
I had a leak today and the LC error was displayed. The car will not be pulled out; the builders secured it while there was no tabletop. How can I solve this problem
Slope
This is from a series about a car, I had an oil leak, but the hood was secured at the locksmith station and it won’t open! How can you solve the problem?
Paddle Wheel
Hooray, I read the reviews and tilted it and the error was erased for me too
Digital Timer
Booka
Good afternoon. I came across this topic while looking for a solution to another "tC" error. But I will also speak out about "LC". This error also appears to me periodically. I approached the solution to the problem having a technical education and experience in repairing washing machines, so I determined that the error appears when the pressure switch (water level sensor) does not “see” the level and the PMM siphons off the water. This can happen due to clogging of the line connecting the PMM ladder and the pressure switch. Therefore, I simply used a pump to blow through the transparent tube from the pressure switch towards the drain, having first removed the side (right) cover. Presostat is easily accessible there. I haven’t heard about the tilt, but if the opportunity arises again, I’ll try it)).
Now I have the "tC" error immediately when I turn on the PMM. Sometimes it disappears and the PMM starts, but does not heat the water. The heating element is alive, I blame the temperature sensor, but it rings and changes resistance when heated, but this is what the cold value should be. Has anyone encountered this?
- 2 Replies
- 23715 Views
Last post by andrewa4
