The top of the dishwasher was filled with water - how to fix it?General questions about dishwashers
Denis
Post by Denis »
Siemens SR64E003RU. It just so happened that water flowed from the tap over the gas stove and, accordingly, down the dishwasher. Maybe 2-3 liters were spilled. Of course, not everything was included in it. The dishwasher automatically turned on and began draining water. In cycles every minute or so. The buttons on the panel do not work. The lights don’t light up. Turning off - plugging into the network - zero reaction. After turning it on, it continues to drain.
Questions: 1 - can water from outside really get into the dishwasher?
2 - Should I wait for general drying or
 Re: The top of the dishwasher was filled with water - how to fix it?
Before the program starts, dishwashers drain the water that is always in the bottom, you just may have a little more of it, wait until it drains the required amount of water.
Water has got into the pan or onto the end of the aquastop system, and the evacuation pump will work until you remove the water from the pan, it can dry out for a very long time, I advise you to open the side and remove the water with sponges or a syringe
Do not open the door, but unscrew the side panel
  • Filled PMM Hyundai 480
    by Tatyana3915 » » in Other manufacturers
    Last post by Construction plant
  • PMM SMS50E02EU/02 heat exchanger is not filled
    by Boris » » in Bosch
  • Water does not flow into the dishwasher. No water. Reasons for the error.
  • Water in the dishwasher
    by Ekaterina.evstafieva » » in Bosch
    Last post by reached
