PMM SMS50E02EU/02.
The machine worked without problems, but while fixing the leak, it was discovered that the heat exchanger was only a third full.
Water enters the machine, is heated and drained.
The valve at the bottom right is loud (it has been working for so long, maybe always)
What could be the reason?
PMM SMS50E02EU/02 heat exchanger is not filled ⇐ Bosch
Автор темыBoris
Artem
Re: PMM SMS50E02EU/02 heat exchanger not filling
Incorrect installation of the PMM machine, control unit failure, circulation pump faulty, water supply valve broken, pressure switch faulty, water flow sensor faulty, control unit faulty, wiring or contacts damaged
- 7176 Views
Last post by Shmel
