How to drain the water from the dishwasher in the winter at the dacha?General questions about dishwashers
Larisa
Post by Larisa »
Forum members, share your experience. How to drain the water from the dishwasher in the winter so that it does not defrost?
 Re: how to drain the water from the dishwasher in the winter at the dacha?
To keep it from freezing, you wanted to ask? :) You can drain the water through the drain hose; you only need to lower it as low as possible, literally to the floor level. But water can remain in the salt tank. When it freezes, the tank will burst, it’s been verified :) To prevent this from happening, you just need to add salt for the PMM. And leave the salt tank open.
when
Новичок
My dishwasher: SGV57T23EU
Post by when »
In the instructions for the Bosch PMM it is written how to prepare for wintering (the mechanism is the same as preparing for transportation), it is necessary to drain all the water from the tank, and not just drain the hose.
  • I want to buy a dishwasher for my dacha, there is no running water
    by stranger » » in General questions about dishwashers
  • Flavia Ivela does not fill with water after winter
    by gesha » » in Flavia
    Last post by gesha
  • Dishwasher did not drain water
    by Slavic » » in Bosch
    Last post by Screams
  • Weissgauff dishwasher does not drain all the water
    by Folk » » in Other manufacturers
    Last post by Folk
  • psm at the dacha
    by Nina » » in Hansa
    Last post by Nina
