My hansa at the dacha before winter everything was turned off. drained the water. In the spring we started everything up normally and started working in the set mode
then the IVF mode immediately switches. loud beep and then stops. In the instructions, this mode means overflow
of water and water flows out from under the bottom. Can anyone tell me what’s wrong with it.
psm at the dacha ⇐ Hansa
- 2 Replies
- 29453 Views
Last post by when
