Good afternoon.
We purchased a Bosch dishwasher a year ago and had no problems using it. Now, every time you turn it on, the machine draws water, turns on the faucet indicator and drains the water. So it drains 2 times and then works fine. At the very end, after drying the dishes, the faucet indicator turns on again and freezes in this position until it is turned off.
Has anyone encountered such a problem and can the program fail if the machine does not have a ground?
The machine often drains water ⇐ Bosch
Автор темыkirill
Re: Machine drains water frequently
pressure is normal. We even tightened it a little so that it wouldn’t be too strong.
Ruslan
The problem is about the same, but the machine does not wash the dishes in the end. The following happens: the water supply is turned on. That’s it, the water has filled up. then the screw begins to spin, as I understand it, this is pressure rinsing. Lasts only 5-10 seconds. Then the "faucet" indicator lights up and that’s it, the water starts draining. WASHING IS COMPLETE!
I turned the car over, removed the bottom, figured out what a “float” and a sensor are in case of a leak. But this is completely different. When there is a leak and the "float" is activated, the "faucet" indicator blinks, but in my case it just lights up.
