The machine does not drain water after the first or second washElectrolux
Marina
Post by Marina »
Good afternoon, please help me with advice. 🙏🙏 🙏🙏 🙏the dishwasher, after a broken hose, which was replaced, stopped draining water after the first wash (main program), and after the second ( eco program), but it drains perfectly and collects water for the second wash, but when the programs are reset, it drains. Cleans well. It’s all been completely cleaned and we can’t understand anything. Please tell me what to check and what the reason could be.
Pipette
 Re: The machine does not drain water after the first or second wash
Post by Pipette »
Well, if there is no blockage in the filter, hose, siphon or in the drain route, then check again that the drain hose is connected correctly, there should be no creases or kinks, the height of the drain hose connection is at least 50cm from the floor)
  • The new machine does not wash
    by Elenaled » » in Hotpoint-Ariston
    Last post by Elenaled
    by Olga Olga » » in Indesit
    Last post by Olga Olga
  • The water supply was turned off during the wash!
    by Igor001 » » in Bosch
    Last post by Igor001
  • Water does not enter the machine. What to do?
    by MyDoHoles » » in AEG
    Last post by MyDoHoles
  • The machine often drains water
    by kirill » » in Bosch
    Last post by Ruslan
