When the program is turned on, water is drained and water is collected without stopping the drain.Indesit
Olga Olga
Post by Olga Olga »
Good evening
question about the Indesit dishwasher
I finished washing, I don’t unplug the machine, I make a new bookmark and select the washing mode. I turn on the start and: the machine drains the water, then, without ceasing to drain, the water set is turned on and the machine draws and drains water at the same time, after some time (30-60 seconds) it stops, and after a few seconds the water begins to drain again and again, without ceasing to drain, the set is turned on water and the machine draws and drains water at the same time, this happens until I unplug it and turn it on again. Here the water is already drained, and then the water is collected and washed according to the cycle.
Please tell me why this happens, the drain hose is vertically located at a height of 60 cm, it’s annoying, and how can I turn on the delayed start?
  • The water supply was turned off during the wash!
    by Igor001 » » in Bosch
    Last post by Igor001
  • Water does not drain
    by TatyanaOren » » in Bosch
    Last post by TatyanaOren
  • There is water left on the 4-hour program
    by Irina » » in Bosch
    Last post by Irina
  • Dishwasher did not drain water
    by Slavic » » in Bosch
    Last post by Screams
  • Beko does not drain water
    by Lord Curzon » » in Beko
    Last post by Lord Curzon
