11477 fills and immediately drains waterHotpoint-Ariston
Elias
Post by Elias »
Good afternoon. The dishwasher began draining water immediately after filling, indicators 1 and 3 were flashing. Moreover, if you open and close the door during a fill, the cycle proceeds normally, either until the end, then until the next fill... I took it apart, no leaks are visible. Where to dig? Thank you.
 Re: 11477 fills and immediately drains water
Post by Fulcrum »
Water level sensor
Kreutzkopf
Post by Kreutzkopf »
The hose to the pressure switch or the pressure switch chamber is clogged
  • Fills with water and drains after a while
    by Krekc » » in Bosch
    Last post by Krekc
  • The machine often drains water
    by kirill » » in Bosch
    Last post by Ruslan
  • Dishwasher constantly drains water
    by Stirlitz 0512 » » in Siemens
    Last post by Stirlitz 0512
  • It fills with water, then it hums and that’s it!
    by Anton36 » » in Hansa
    Last post by Puppeteer
  • Constantly fills with water.
    by Alexander34 » » in Electrolux
    Last post by Alexander34
