Has anyone encountered the error: E:60-02?Bosch
Clumsy_2023
My dishwasher: SPV6HMX4MR
Post by Clumsy_2023 »
When starting any washing program - Bosch dishwasher SPV6HMX4MR hums and makes noise, but water does not fill and the cycle does not start. Then error code -E:60-02. In the operating instructions this error code is not mentioned. Possible causes of such a problem (activation of Aquastop, abnormal operation of the pressure switch, leakage into the pan, etc.) have other error codes. There is also no information about this error code on specialized websites on the Internet. Has anyone encountered anything similar?
Clumsy_2023
 Re: Has anyone encountered the error: E:60-02?
We managed to find out that dishwashers have Bosch with Home Connect control system - new error codes are used. Error E:60-002 is formulated as "Circulating pump blocked" - The circulation pump is blocked. This error code is almost the same as error code E24 in models without Home Connect. In my case, the cause of the blockage was wear of the graphite bushings of the shaft. Because of this, the impeller did not rotate and the pump did not work. After replacing the graphite bushings, the error went away and the machine is operating normally.
  • Who has encountered error E33-00 and how to cure it?
    by the drag » » in Bosch
    Last post by the drag
  • error E31
    by Anastasia » » in Bosch
    Last post by Cheer up
  • Error E19
    by Sergee » » in Bosch
    Last post by Serg
  • Error E1
    by Dmitry79 » » in Chrono
  • Error e14
    by SF2015 » » in Bosch
    Last post by mario
