Error E1Chrono
Dmitry79
Новичок
My dishwasher: Krona BDE 4507 EU
 Error E1
Post by Dmitry79 »
Good day. Recently the issue with error E4 was resolved. I thought life was getting better. and here is E1. The instructions indicate that there is no water supply. The valve is closed. but everything is included. There is pressure. The permostat or whatever they call it pumps. makes noise. The water flows, you can hear it start to turn and the fence goes. It makes noise and makes noise and after 10 minutes it beeps and error E1. I tried putting it on rinse, it works, and then it dries. and now there are other modes, an intensive, normal error in the end. but there is water.flowing.and the pressure is good, we don’t live in a village.
Sent after 1 hour 7 minutes 28 seconds:
I noticed a peculiarity. when the opening of the detergent dispenser should work, it does not open and then error E1 appears. and there is water. the brains don’t see the autopsy and that’s why they’re dumb. What is it like, is it being treated?
Dmitry79
Новичок
 Re: Error E1
Post by Dmitry79 »
I’ve come home now. set the rinse. I filled up the water and then the error happened again. Then I turned off the tap. I put it on the sink, pulled, pulled, drained, and in the end it was E1 again. It’s clear that there is no water supply. then I already loaded the detergent, selected the program, opened the water supply again, it started again, drain, set, rinse, I think it will turn off. No. I hear the click of the dispenser, the detergent has been thrown out and is still washing. Before this, every time in the morning, immediately after typing, it gave an error. This is where to dig. nothing is clogged. This means that the electronics of the brain compose. but which one exactly? After all, this is not a complete treatment. but temporary.
Sent after 38 seconds:
and At the moment it erases without problems. *x)
Dmitry79
Новичок
 Re: Error E1
Post by Dmitry79 »
and it happened again yesterday. We install a car wash once a day. So, E1 was issued immediately after taking water. I turned off the tap, turned it on again, waited, after 40 seconds I opened it and the water started flowing. it came to rinsing after an hour with kopecks and the error signal sounded again e1. water supply. did the same thing again. but the program has already gone astray. I turned everything off, turned it off, started rinsing separately, opened it after a while until an error occurred, and everything worked. Water intake completed, rinsing and drying completed. Everything is ok. That’s what’s to blame for this, where is the dog buried?
Dmitry79
Новичок
 Re: Error E1
Post by Dmitry79 »
For whom the forum is interesting. Just write like that. I understand that there are no specialists here... well, maybe it will help someone. I’ll answer myself - the issue is resolved. the problem was in the cochlea, the so-called water restart labyrinth. One channel there was clogged and therefore water took a long time or did not collect at all. replace the snail and everything is fine.
 Re: Error E1
Where is this snail located?
 Re: Error E1
Teka dishwasher stuck on error E1 and that’s it
  • error E31
    by Anastasia » » in Bosch
    Last post by Cheer up
  • error E22
    by Evgenia » » in Bosch
  • Error A05
    by Langollier » » in Hotpoint-Ariston
    Last post by Aksenov
  • Error E 27
    by Vitaly » » in Siemens
  • Error e17
    by Victor » » in Bosch
    Last post by Victor
