error E22Bosch
Evgenia
 error E22
Post by Evgenia »
Hello! !
The dishwasher gives error E22.
It is not in the description ((
Tell me what this means?
Romych
 Re: error E22
Post by Romych »
Apparently, this error indicates the presence of residual water in the pan. This may be due to a dirty filter. Take it out, wash it.
Remove all the dirt you can reach from the place where the filter is.
Also try pouring hot water from the kettle there for better cleaning.
Svetlana
 Re: error E22
Post by Svetlana »
Hello, it gives error E22, I took it out and cleaned the filter, but there is water in there. Is it possible to pour citric acid in there and start the machine?
 Re: error E22
You need to remove the water with a sponge.
 Re: error E22
There should be some small amount of water at the bottom of the dishwasher; there is no need to remove it. You can try cleaning it using the method described here http://posudomojki.ru /viewtopic.php?f=21&t=172
  • error E31
    by Anastasia » » in Bosch
    Last post by Cheer up
  • Error A05
    by Langollier » » in Hotpoint-Ariston
    Last post by Aksenov
  • Error E 27
    by Vitaly » » in Siemens
  • Error e17
    by Victor » » in Bosch
    Last post by Victor
  • Error e14
    by SF2015 » » in Bosch
    Last post by mario
