Error e14Bosch
SF2015
My dishwasher: Bosch
 Error e14
Post by SF2015 »
Spv58m50 we have such a dishwasher. We used it maybe 8-10 times. And then, after turning it on again and starting to wash, the machine started beeping for about 3 minutes. Error e14 on the screen. The car washes, but it sucks. It doesn’t wash everything, it feels like it doesn’t have enough water.
The Internet for error e14 says that there is a problem with the sensor for the amount of incoming water.
The question is, what model of the sensor is, its article number and how to check whether it works or not.
mario
Наблюдатель
Наблюдатель
 Re: Error e14
Post by mario »
Perhaps this is the sensor fooling. In my case, I removed it and moved it manually - it simply jammed. Since then, the flight has been normal for two years.
Have you tried disconnecting it from the network for an hour?
SF2015
 Re: Error e14
Post by SF2015 »
You don’t have a photo of where this sensor is located.
Thank you.
mario
Наблюдатель
Наблюдатель
 Re: Error e14
Post by mario »
No, unfortunately.
You can look at the plastic tank (where the water is collected) on the side. At the bottom there is also a valve with wires. He also eats, sometimes. It can be removed and checked. He is responsible for the water supply.
  • error E31
    by Anastasia » » in Bosch
    Last post by Cheer up
  • error E22
    by Evgenia » » in Bosch
  • Error A05
    by Langollier » » in Hotpoint-Ariston
    Last post by Aksenov
  • Error E 27
    by Vitaly » » in Siemens
  • Error e17
    by Victor » » in Bosch
    Last post by Victor
