Error codeElectrolux
Ilya
 Error code
Post by Ilya »
Dishwasher 505052 Electrolux displays error C7.
Tell me who knows what this error means.
 Error code
Ilya:Dishwasher 505052 Electrolux gives error C7.
On Electrolux C7 washing machines this is a heating element error. I don’t know for sure about dishwashers. :( Maybe too.
Evgeniy M
 Error code
Post by Evgeniy M »
Fault name
Screen display
EDW 150
LED signal END
2Hz/5sec pause
EDW 110
nBrief description
malfunctions
What is happening?
The water supply tap is closed
I 10
1 flashing
The pressure switch switching threshold level has not been reached within a maximum of 60 seconds
(only in program phases that include filling to the level!)
n
The program stops and can be resumed after the error is corrected by pressing the program button. If the program button is pressed and the error is not corrected, the machine runs without water until the next subprogram.
Drain pump
I 20
2 flashes
The pressure switch reset level has not been reached within a maximum of 120 seconds. The program is stopped.
The program stops and can be resumed after the error has been corrected by pressing the program button.
AQUA control
I 30
3 blinks
The water control system has directly disabled the fill valve.
The program stops and automatically starts again after the fault is corrected.
Circulation pump
Short circuit of thyristor
I 50
5 flashes
Signals from the tachogenerator are detected, while the circulation pump is not turned on.
Program stops and water is filled to the pressure switch reset level.
Heating
I 60
6 blinks
During heating for 3 minutes, the water temperature does not increase by at least 1.5 K
The program runs to completion without using the heating function.
NTC thermistor
I 70
7 blinks
NCT open or short circuit
The program runs to the end without using the heating function.
EEPROM
I 80
8 blinks
Communication error with external EEPROM
Checksum MCF / CCF
I 90
9 flashes
Incorrect checksum (programming model) MCF or CCF.
Detected only after switching on!
Program selection is not possible.
ON/OFF LED is on.
Sprinkler is locked
I A0
10 flashes
At the beginning of the program and each subprogram, as well as after opening/closing the door or power outages, the rotation of the sprinkler is checked and evaluated.
Message about blockage or error until the sprinkler speed is determined.
Transparency sensor
I b0
n
11 flashes
The water clarity signal required for calibration was not received within 15 seconds
Determination of transparency always occurs. According to this indication, the program route is adapted.
Communication error
I C0
12 flashes
Loss of connection with the User Interface
The machine stops and waits until the connection is restored.
Tachometer
I d0
13 blinks
The circulation pump is turned on, but there is no signal from the tachogenerator for 5 + 20 seconds
The circulation pump is uncontrollable, heating is turned off.
This function is checked again at each stage of the program.
Water filling time error
I F0
14 flashes
The time limit when filling with water has been exceeded.
The program is executed until the next subprogram when the level of water filled is insufficient. There is no further filling of water to the required level. The error disappears after the drain is completed.
 Re: Error code
What does 4 blinks mean?
  • Error code U1
    by Natalya Verezgova » » in Flavia
  • Aeg error code 160
    by Yuri » » in AEG
    Last post by Yuri
  • ESL46050 error code i10
    by Guest » » in Electrolux
  • Bosch dishwasher gives error code 22
    by Eugenia » » in Bosch
    Last post by Yuri
  • Hotpoint Ariston LSF 8357 error code A1 help!
    by Ksenia » » in Hotpoint-Ariston
