ESL46050 error code i10Electrolux
Hello everybody. I came across this problem. I turned on the machine as usual at night. In the morning - the machine hums, as if it is pumping out water, the error code is displayed i10 - i.e. no water supply. Interestingly, when the PMM is turned off, it still buzzes. It stops only when disconnected from the network. The next time you turn it on, the same picture occurs. If you select a program and start it, the PMM turns on the water supply for about 5 minutes (the water flows exactly, the water meter spins), drains the water, then the supply is turned off, error code i10 is displayed. Tell me what it could be, maybe someone has encountered such a problem.
Mix
 Re: ESL46050 error code i10
Post by Mix »
Try tilting it 45 degrees and rocking it slightly. The float may be stuck.
PMM, after standing for 2 days, started working on its own. Perhaps it was a matter of salt; the salt absence indicator was on for several days before the “breakdown.” On Sunday I added salt, the PMM did not work, now it works, such miracles
Good evening. Error code i30 is displayed, what could be the problem?
  • Error code
    by Ilya » » in Electrolux
  • Aeg error code 160
    by Yuri » » in AEG
    Last post by Yuri
  • Error code U1
    by Natalya Verezgova » » in Flavia
  • Bosch dishwasher gives error code 22
    by Eugenia » » in Bosch
    Last post by Yuri
  • Hotpoint Ariston LSF 8357 error code A1 help!
    by Ksenia » » in Hotpoint-Ariston
