Error code U1Flavia
Natalya Verezgova
 Error code U1
Post by Natalya Verezgova »
Dishwasher Flavia B1 45 NIAGARA. The machine did not complete the washing process and issued code E1. I tried to clean all the filters. Code E1. I called the service center and they said that most likely the auto-stop inlet hose was broken. Need to change?
 Re: Error code U1
Good afternoon, Natalya!
If after rebooting the dishwasher, disconnecting from the power supply, the error does not reset and there is no water supply when you turn on some mode, then yes, you need to change the hose with the aquastop. You can order it from us: inlet hose - (673000900331) , order by mail info@flavia-rus.ru
  • Error code
    by Ilya » » in Electrolux
  • Aeg error code 160
    by Yuri » » in AEG
    Last post by Yuri
  • ESL46050 error code i10
    by Guest » » in Electrolux
  • Bosch dishwasher gives error code 22
    by Eugenia » » in Bosch
    Last post by Yuri
  • Hotpoint Ariston LSF 8357 error code A1 help!
    by Ksenia » » in Hotpoint-Ariston
